VGA Replacement Parts?
Superjoe
I have a GTX 460 Cyclone. One of the blades of the fan snapped off. Does anybody know where to buy replacement parts? Can't use any aftermarket cooler on this thing apparently.
Already emailed MSI, but I expect it to take a while for the reply.
Thanks!
MSI won't send you replacement fan,of that I'm 95% sure.I once had a fan go bad,not a broken blade,just excessive bearing noise,and requested a replacement fan to avoid RMA headache,they refused.Also physical damage may void your elegibility for RMA,but I'm not certain on their policy regarding that,good luck either way.
I think gelid icy vision fits your card,but you may want to double check that.As a last resort you could just rig a different fan to the cooler.
