ehZn said:The only downside to using DVI is that some lcd image adjustment functions no longer work when using DVI (usually because they are no longer necessary).
Aerobahn said:so DVi has a better picture if im not mistaken.
Not entirely true! The HT markets have pushed to support extremly long runs of DVI, and now some use fibre for runs over 40' ... which basically skyrockets theoretical limits of distance, and cost!mikeblas said:Well, there are some other downsides. DVI cables are a touch more expensive than VGA cables, and can't be run over great distances.
There is not much infrastructure support for DVI yet, either. There are no signal boosters, like you might use to run a VGA signal over very large distances.
Some infrastructure doodads are quite expensive (or hard to find) for DVI, but they're well-established and inexpensive for VGA. KVM switches, for example; or repeaters you might use to send the same signal to many monitors.
Maybe these issues will get better in the future as DVI gets more popular. Or, maybe they'll never get better -- perhaps DVI will be replaced by something else before these problems sort themselves out.
.B ekiM
nweibley said:which basically skyrockets theoretical limits of distance, and cost!![]()
ehZn said:DVI right now works mainly on single link, while future devices can work on a dual link which should provice faster transfer times, sharper picture, and greater overall bandwidth.
