vga cooling
VGA cooling is cooling for video cards. I'm not sure if all vga coolers can be mounted onto the Northbridge, but I guess it can be done if there are mounting holes around it.
they make coolers that are marked as vga/chipest coolers because if it fits a chipest it will fit a video card aswell. that is if it uses just the holes and clips on to the pcb's and nothing else.
