Hi,
Anyone out there with this setup ? And maybe flashed with the PE bios ? After testing this weekend I found out my LOAD temps to be 90ish at full load, FEAR and Oblivion with high settings at 1680x1050, thats pretty worrying isnt it ?
I thought at first I was fine since rthdribl after 15 mins wouldnt go higher than 65C. Idle temps are 43-46C.
I should try remounting before thinking its a crappy vga cooler right
Its either that or the card just cannot take the PE bios and the high voltages it takes.
