Vesa stand for 3 monitors?
null
Can anyone recommend a vesa monitor stand for 3 20" monitors? Each monitor weighs around 6-7lbs. I need a stand, not a mount that clamps to the desk.
Here is the one I'm considering: http://www.amazon.com/dp/B001NPEC5A/
... although I'd like to see if there are any that work just as well for a less.
My main concern is sagging; I'd like to be able to find tune each monitor's height so that they're all horizontally aligned. E.g. I wouldn't want the center monitor higher or lower than the outer 2.
This will be my first vesa stand, so wanted to see what some of you recommend before pulling the trigger.
Whoops, forgot - all 3 are 20 inch and weigh around 6 lbs a piece. OP has been edited.
