VESA releases DockPort specification
octoberasian
http://www.anandtech.com/show/8106/vesa-releases-dockport-specification
With Computex now in full swing this week has and will continue to be a flurry of product and standard announcements. To that end and kicking off their Tuesday, the VESA has sent us a status update on DockPort, the organization’s combined display/data/power cable and interface standard.
The last time we talked to the VESA was at CES 2014. There, the organization announced that they were adopting AMD/TI’s Lightning Bolt specification as a VESA standard, and were in turn making it an official extension to the DisplayPort standard. At the time the DockPort specification was still in development, with a projected finalization of Q2’14.
The logo will also notify people which DisplayPort devices support DockPort capabilities, which now carries USB 3.1 compatibility.
Is this the contraption that would allow the daisy chaining of monitors through one displayport?
Much more.
This is meant to be a counter or alternative to Intel's Thunderbolt, with the exception that this, DockPort, be a more open standard not locked down by one manufacturer.
With DockPort, and like Thunderbolt, DockPort-enabled DisplayPort devices can act not only as a display connector but also connect to other devices like hard drives, mice, etc.
Much more.
This is not at all a competitor to Thunderbolt, Thunderbolt uses PCI-e, this is just USB.
While the technology behind Thunderbolt and DockPort is quite different, the use cases certainly overlap.
Its mainly for laptops, have keyboard and mouse connected to monitor then all you need to do is connect the dp cable to you laptop.
But that can already be done with Thunderbolt (and even better, thunderbolt supports PCIe devices). Imagine docking your laptop and suddenly having a GTX 780 powering your external display. Possible with Thunderbolt, not possible with DockPort.
If this is mainly meant for laptops / tablets with limited expansion options, then not including PCIe devices support seems like a HUGE omission. Most users would be served just as well by using a USB 3.0 dock...
Dockport = uses AMD ideas.
Therefore Unknown One will fiercely oppose it, wether he knows it or not.
I see it as similar to USB2 vs firewire or vhs vs betamax.
Those with high end needs will be prepared to pay the premium (on both the computer and the device(s)) for thunderbolt
Those who just want to reduce the number of cables needed to hook up their laptop to the usual array of stuff (keyboard, monitor, mouse, printer, network, maybe a couple of external drives) will be satisfied with a cheaper solution.
Well, the PCI-e lane would be awesome, but in truth, just like FireWire, the public is going to go with the available option. With a heavy emphasis on availability, and useful features, I think dockPort will do well.
Much more.
Yeah, yeah, that's nice, but wasn't this supposed to come out two years ago?
Sorry for thinking this was an alternative to Thunderbolt. My mistake.
As for this coming out 2 yrs ago, I'm not sure. Think this was worked on since then.
