vesa mounting a 20" lcd
leetskeet
i was wondering if putting a vesa mount into drywall would suffice to support a 20" lcd. i'm not sure about studs being available so i was wondering if anyone had any experience anchoring a vesa mount only in the drywall. any advice would be great.
I would not risk mounting it like that, with drywall being the only thing holding it.
You are best off using a stud finder, and then mounting it properly.
The other option is to use a vesa desktop base mounting system, which some members on here seem to fair well with.
