Vesa mount for node 202
blaight
Do you know of any good solution to fix a Node202 to a Vesa mount? Perfeclty even behind the monitor.
there are ways you can do it, but regardless of mounting, I wouldn't trust the case to hold up to it. I have a raven rvz-01, which is effectively the same case, and I don't think I would trust it to hold up to being mounted very well. Certainly not if you wanted it to be vesa compatible on both sides - that is, sandwiched between monitor and mount.
Oooh, gotcha. Those are cool, I haven't seen them before. That being said, Ergotron is already the most likely to have what you're looking for; they're really the only super-high-end vesa mount player.
Well yes, there are some of these available in Germany, but they are limitied to 70 mm width and the Node is 88 mm.
