Very upset
I have a 4 month old case from xoxide, the x superalien mid tower, it comes with fan control and a little lcd which shows cpu temp and hd temp. I beleive the cpu temp is broken, as it is stuck on 25 celcius, i have even tried restarting, which usually makes the temp fluctuate. The hd temp did fluctuate but this is still on 25, i even turned the fan speed up but its still there. What can i do to fix? can i reset it somehow?
check all the connections for the temperature guage. Do you place the temp reader near CPU or what?
Overall it sounds like an xoide problem to me. Shoot them an email
not sure actually, but i unplugged all the power things to everything, then replugged everything and it works thanks tho
