Very strange problem with my cd drive...
Ricedaddy
I am having a very strange problem with my cd drive.
I pre-ordered The Lord of the Rings Online and got a dvd with it to play the open beta. The dvd spins up but won't read the disc.
I also just tried to install Call of Duty 2 and same problem.
However, I load up a disc that is on cd rather than dvd and it works fine.
The drive is a Sony cdrw/dvd reader, so what is the problem? Is it that the dvd lens is jacked?
thanks
Don't know if your problem is the same as mine, but I had been unable to install FSX from dvd. I tried to install another dvd game and also couldn't install that. But the cd portion of it worked just fine. After trying to install that dvd game again, I took a look at the Event Viewer and noted tons of error messages about the device itself having an error. Swapped it out with a new drive and everything installed normally.
