Very strange problem, any help would be appreciated
rhufnagel
OK, this is a new one to me.
When i boot the PC there is a weird electrical like buzzing noise coming from the PC but it goes away very quickly. HOWEVER, when I launch a video game, it comes back and does not go away until I shut the game down, or (heres the weird part) minimize it. If I min (alt-tab) the game to the task bar, the sound goes away, bring the game back up, and it comes back. Shut the game down, goes away.
Here are some specs, and what I have tried so far:
ASUS P4C800-E deluxe Mobo
2 Gigs PC 3200 Corsair Ram
P4 3.2 GHz with HT (socket 478)
Geforce 6800 GT 256 MB
XF-I xtrememusic
I opened the case and listened and its not coming from the HD which is all the way up front, I checked all the case fans, I (weird) took out the graphics card and threw in an old hercules gerofre 2 prophet card and the problem went away! I was like, OK its the card, went out and bought a new 7800 GS OC card from BFG, problem came back, just not as bad??? WTH? It sounds like its near the cpu or the graphics card, I even unplugged the cpu fan, no good.
I am thinking maybe its the AGP slot itself, Im sure the new cards draw alot more power than an old geforce 2 card did, so maybe the Mobo is going?
Any suggestions would be greatly appreciated.
You say its an older mobo? Check out the little circle things wrapped in wire on the motherboard.
Those are called toroidal transformers. when they start to get older, their enamel gets crumbly and the electromagnetic vibrations turn into a wierd electrical noise.
If you do have any on your motherboard or video card, touch a pencil eraser to its center to push on the wires and see if you can find the noisy one.
if you do find one;
1 turn off rig, unplug or shut off psu
2 apply some clear nail polish to it
3 alow several hours to dry, dont plug in untill dry to touch on all sides.
If that doesn't work, then ill leave some advice;
That problem lies somewhere in between your Graphics adapter and the northbridge. Im guessing on the mobo because i have a 6800 vanila and it doesnt have any torroids of that style. if youve eliminated all chances of it being a torroid, try a different vid card if possible.
[Christ, i just checked out your mobo. for over $2000 , it better f**kn not be the problem]
