deadman_uk
- Jun 30, 2003
Argh another computer problem!!! ALOT to read, so please if you have the time help me!!
I have 2 hard drives, one is a 160GB ATA100 and the other is a 320GB SATA-II. The 160GB hard drive is used for storage ONLY. The 320GB has windows on it.
I recently bought some new RAM (2gb corsair) and installed it into my machine. I then went round my dads and my brother used my computer for 2 days. My brother rang me up yesterday saying when he turns on the computer a message comes up underneath the writing on the 2nd boot screen saying "system boot failure" (or was it disc boot failure??? I cant remember).
I went home and the same message appeared. I inserted my windows XP disc and tried to format the 320GB hard drive but the screen said the 320GB hard drive had 1mb of used space meaning my whole hard drive had been erased! I only lost a few files (because most were on the 160GB one) but I formatted the hard drive and installed windows. Windows installed successfully but the 320GB hard drive that use to be called C: was now called D: and the 160GB hd which use to be D: is now called C: Anyway I started to put my files back on my 320GB hard drive. I had to reboot because of Norton so I did and I got the "disc boot failure" message again. Everytime I try and start the computer it comes up with that message. I inserted my windows XP disc and pressed F8 on the boot screen to enter the boot menu. I selected the CD drive with the XP disc in and strangely windows loaded fine. I rebooted the computer and it said again "disc boot failure". Everytime I press F8 and go to the boot menu and boot from the cd drive windows loads up fine.
I looked in the BIOS and under the boot menu it had something like...
320GB SATA
160 ATA100
I switched the 2 around meaning I put the ATA100 above the SATA in the BIOS. I rebooted the machine and it could finally load windows up without the need to keep using the XP disc. Both my hard drives are Western Digital so I downloaded a hard drive program off their website that checks for errors on the hard drive. I tested the 320GB hard drive first and it passed the test but when I tried to test the 160GB one, the PC rebooted. I tried several more times and everytime the PC rebooted. Sometimes when I try and access the 160GB hard drive the PC would reboot. I made sure the leads were in properly and the 160GB hard drive has been fine ever since.
A few hours ago, my pc completely froze and I heard one of the hard drives whirling. You know when a hard drive is loading you hear that whirling sound? Well the hard drive was whirling then it made a click sound, then whirling then another click sound... it did that over and over. I turned off the computer and turned it back on and it still did that. The 160GB ATA hard drive wasnt being detected by the computer or BIOS. I pushed the cable in the hard drive to see if it was in properly and it was, the hard drive was detected then after I turned on the PC again. Thinking all my troubles were caused by the 160GB, I unplugged the hard drive and now I get the "disc boot failure" message again!. The only way I can load windows was to plug the 160GB hard drive back in but the 160GB only has files and doesnt have windows on it so what on earth is going on!?
It's like the 320GB SATA drive cant boot on its own without support from the other hard drive. Please help!
320GB SATA
160 ATA100
