Very strange boot issue!
cody45
My PC has decided it did not like to boot normally so it came up with its own. When I turn on the power the monitor turns on and a black screen is displayed for fifteen seconds, then the BIOS screen comes up for five seconds, then another black screen for ten seconds followed by a flash of the BIOS screen again. Then I get another black screen with blinking cursor in the top left corner that lasts a second followed by a short delay before a white loading bar runs across the bottom of the display and is quickly replaced by the XP loading screen and finally the welcome screen. This new boot method adds about a minute and a half to the time it takes to finish loading. After loaded all seems fine! I suspect it is a BIOS issue but I have tried all normal methods to correct this! Thanks, Joe:confused:
Come on guys. Help an old man. Please
Reset the BIOS to defaults - reboot - then go in and set your boot order and any custom settings you had before and reboot one more time. May want to also check and or replace your CMOS battery. While you have the case open re-seat your RAM, video card etc. Check your IDE and SATA cables too. If one has come loose your mobo may be having trouble detecting hardware on boot-up.
