Very Strange and Annoying Router Problem
rise2mcr
Hello [H] members. it seems i have a very weird problem with my router. whenever i try to port forward to any computers on the network, it doesn't forward... canyouseeme.org says that the connection was "Refused". I run multiple Gaming and other sorts of servers, so i need to fix this problem as soon as possible. My router is an ActionTec MI424-WR, and my ISP is Verizon (FIOS 5 up / 20 down if that helps). Thank you for taking the time to read this and thank you all in advance for helping me. if any other information is needed just ask. Thank you!
-Rise2Mcr
That Actiontec can be a little odd to setup - the first time I set one up for forwarding nothing happened, it turns out there a number of setup screens you have to follow.
Check out the guide at www.portforward.com and follow it exactly.
Yes - i followed that guide, and it didn't help me. i still have this problem, i reset the router to default settings last night, and re-booted it, still no luck... any thoughts? :confused:
