Very slow load times w/COD 2
CruzCtrl
First off, I did a search for 'COD2 load' before posting this and didn't see anything relevant.
Using the system specs in my signature please advise why I am experiencing slow load times with COD 2 with start level and level changes (the games starts quickly enough IMO). I am new to this game, down to 25 processes running (only two for user), correct DMA settings w/HD defraged on primary IDE channel and DVD on secondary IDE channel.
I'm sure I've forgot to mention all the variables that are relative but I will answer all things that I know about my rig when I check for responses later this evening.
Thanks for any help with this 'problem'.
P.S. Once the level loads up the game seems to run smoothly enough for my expectations of this rig (no major hesitations or jerkiness).
Hmm, seems like the same problem that I have. Lately I've been having this same problem with my specs, and it even forced me to quit playing the game.
It's no fun being in the middle of a clan scrim and taking twice as long to load as everyone else...
Thats a really old CPU and fairly slow RAM.
I recently did an upgrade to the Core 2 Duo and faster RAM, I've overclocked it a bit as well and it's obvious now that most of my games were easily CPU limited due to having much better performance despite not getting a better video card.
I'd also suggest if you want fast loading you should invest in a faster solution for your primary hard drive, at the very least a Western Digital Raptor 10,000 RPM drive or maybe consider a RAID 0 solution, loading in games becomes very fast, COD2 loading for me recently is only a few seconds on the average singleplayer map which takes me straight into the action instead of having to wait.
You might also look at defragging (Defragmenting) your hard drive, over time your files become fragmented and take longer to read/load on average including game files, you can use windows built in defrag program or grab a 3rd party defragging software online which will often have additional options to optimise the way files are stored, I use O&O defrag and tend to defrag my primary hard drive with a /NAME defrag which orders the whole drive by filepath/filename for fast loading of entire folders of files.
