Thunderbrain
- Jan 29, 2004
For a quad-core system is it better to use the 8 pins EATX12V connector or will the 4 pin one be enough? And please could somebody tell me the difference in use of each one?
I have this 3 motherboards in mind for the build
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131188 (4 pin only)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131180 (4 pin only)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131182 (4/8 pin)
PS: I'm not thinking on doing any type of OC
Lots of thanks in advance!!
