hi,
Ive just recently been getting into LSI / MegaRaid HW raid cards and thus MegaRaid Storage Manager. Prior ive always used adaptec HW raid cards. Maybe im missing something obvious, but is it not possible to mix RAID 5 and RAID 6 (example) arrays (or VDs as they are called in LSI) on the same set of disks?
I often do this on my adaptec cards. for example, lets say i have 6 x HDDs (2tb drives for example) attached to my 9271-8i card, is it possible to have a 3TB RAID 5 array, and also a 2 TB RAID 6 array on these same 6x HDDs? Or must i choose one RAID type and stick to it for all VDs created on these 6x physical HDDs?
here is the line from the LSI MSM (MegaRaid Storage Manager) that is driving me crazy:
NOTE Having virtual drives of different RAID levels, such as RAID 0 and RAID 5, in the same drive group is not allowed. For example, if an existing RAID 5 virtual drive is created out of partial space in an array, the next virtual drive in the array has to be RAID 5 only.
What im asking, is can you have a RAID 5 and a RAID 0 and a RAID 6 on the same set of disks? On every type of RAID card ive used so far this is possible (adaptec, arcea, hpt, even old promise cards
), but it seems on LSI you can *not*. this is going to be a huge issue if its not possible as i often have different raid types on the same set of disks in order to maximize disk space usage..
Thanks!
Thanks!
