Very low fps?
lazerxo
Operating System
Windows 7 Home Premium 64-bit SP1
CPU
AMD A8-6600K 63 °C
Richland 32nm Technology
RAM
10.0GB Dual-Channel DDR3 @ 664MHz (9-9-10-24)
Motherboard
ASUSTeK COMPUTER INC. A55BM-E (FM2+ ) 42 °C
Graphics
2252W (1920x1080@60Hz)
2047MB NVIDIA GeForce GTX 760 (EVGA) 44 °C
Storage
465GB Western Digital WDC WD5003AZEX-00MK2A0 ATA Device (SATA) 31 °C
Optical Drives
HL-DT-ST DVDRAM GH24NS90 ATA Device
Audio
Realtek High Definition Audio
thermaltake 600w
are my specs, I tend only get 120 fps on league of legends any advice would be appreciated thank you.
Since when is 120FPS low? Maybe make sure VSYNC is turned off. Have a feeling LoL is more CPU limited than GPU. Turn down the settings.
This seems really silly unless I'm missing something.
Yeah 120 fps is low? You have a mid range cpu and mid range gpu so if anything that is amazing.
120FPS, that's reheheheally low!!!! Time to get a GTX780 ;)
you are running an A8, you are most like CPU bound.
is the GPU loading at 100%?
RAM
Is this a typo? 664MHz for your RAM?
RAM
664 * 2 is basically 1333 (it's close enough), don't forget DDR stands for Double Data Rate.
Count me in with the 120 is low? category. I remember playing Crysis 1 on a GF 6800 that was overclocked to within an inch of it's life and even then I was getting ~20fps.
RAM
I'm guessing hes looking at cpuz and seeing the normal 50% number on there, much more likely he means 1328 mhz.
And to the OP, why do you think 120 fps is low? Your monitor (60hz refresh) won't display anything over 60 fps anyways. 120 fps is actually quite high lol.
RAM
Also, 10.0GB? Is this reporting available memory or total memory? DDR3 RAM sticks only come in 2, 4, or 8 GB flavors...
4 + 4 + 2
8 + 2
I could see 10 happening, however in any dual channel board it's less than ideal. (wow, I totally missed that one)
4 + 4 + 2
8 + 2
Doh! You're right... Yeah, 8+2 is not going to be happy in dual-channel mode...
