I've recently built a new computer here are the specs
AMD Athlon X2 4800+
Asus A8N-SLI
1 Gig of DDR400
1 74GB Raptor and a Seagate 120GB IDE HD
eVGA 7900GT
Win XP Home
For a while it was working perfectly, A couple weeks later the boot up process took an insane amount of time, it would take about 1 min 45 seconds of showing the windows loading screen with the scrolling blue bar. Once it would actually get to windows and load a few programs it would reset itself.
I could boot into safe mode and do everything fine. I thought it was some sort of spyware or virus, scanned it with plenty of software and found nothing. I decided to use CCleaner and get rid of any possibly problems with that, that seemed to have fixed it for some time. Bout a week or so later it happened again, the long boot up time followed by reseting after windows is loaded. Went into safe mode and did everything all over again, the only problem is that it didnt fix it and nothing would.
So I just said screw it and I am sick of dealing with the problem. Disconnected my IDE drive so I could format my raptor and have it labeled as C Drive. Formatted, everything was fine, after installing some basic things it all seemed okay. So I reconnected my IDE drive and installed some more things and when I reset my computer the boot up process takes forever again. I've timed how long it takes and it is around 150 seconds, I've tried using a bunch of software to analyze it and see what drivers are being loaded that could possibly be causing the issue but I cant tell. I can get into windows fine, it wont reset itself after I formatted it but the boot up process takes forever still.
Anyone know some options or software that can tell me whats going on? Is it some driver having problems? Or is it some virus that has been on my IDE drive?
AMD Athlon X2 4800+
Asus A8N-SLI
1 Gig of DDR400
eVGA 7900GT
Win XP Home
