VERY High Temps EN9600GT
bdrx9c
Almost exactly a month ago I bought 2 ASUS EN9600GT/512M's from NewEgg for a budget SLI setup. About a week ago I went to convert a video and got a blue screen. After about a day of figuring out what was causing that I figured out my CPU was getting way too hot and causing my system to crash. I found it kind of odd because it hadn't done this in the past. So I bought a ThermalRite SI 128 cooler for it which helped out a lot. But when I was looking in Everest to check the new temps with the new cooler, I noticed what was causing the CPU to heat up so much and it almost makes me sick to my stomach. Both of my 9600's were idling at 80C. Now, I'm normally an ATI fan where my old X850XT would overheat and artifact at 70C. I do know that Nvidia cards run a bit on the warm side as compared to ATI but 80C idle seems... HOT.
make sure you have adequate airflow in between the cards. airflow is the key to a properly cooled system. also i highly doubt the video cards are the cause of your cpu overheating....that's just a weird assumption especially if you have a exhaust fan right behind it.
im just going to assume it was mounted incorrectly or you did not apply enough or applied to much paste on it.
Actually there was a 5C rise in temperature from the logs I had before the video cards. The issue with that is, the CPU cooler is so big that there is no clear exhaust path between the video cards and the cooler. I've been running with the side panel of the case off but I suppose that really doesn't help with the stagnant air. I suppose my next course of action would be to add a fan to the side panel to get some forced air into the cards' heatsinks. 80 degrees just seems really high even for poor airflow.
80º IS high for idle temp...What's the default fan cycle for your cards ?
Airflow is definitely important and you should try not to have everything crammed up inside the case, but the dedicated fan for the video card, shouldn't allow such high temps, especially at idle.
I am thinking its a fan speed issue. EVGA Precision Tool can set fan speeds for both cards in SLI. Give it a try.
