shadowwyvern
- Sep 22, 2005
I am gettign rather desperate. I am runnign a zalman 9500, which I have installed twice, and am currently getting no response in my thread regardign that installation, so I figured I would attack it from a different angle. Can the vanilla p5B read core 2 temps right? The board brags abvout being core 2 ready, but it seems as though I need a bios update anyway (uCode error on boot that I can dismiss, people have said a bios update fixes it). It starts at around 44C, then rises to 50C as I watch it in bios. Used as5, had a blob that the hsf aquished - should I have done it dfferently? I can move the fan a bit, like 5-10 degrees somewhat easily when i try to twist it, otherwise it does not move. A visualinspection shows the fan installed exactly as instructed, clips are definatly putting an ample amoutn of pressure on the proc.
I do not have a windows install yet, and I need to run memtest/prime95 for a total of 3 days, need to be a t a lan in 1 week, at college in 10 days, so this need to be DONE. I apologize to anyone who consioders this cross posting, but I am adressign different aspects of the same problem.
