Very Cheap Minecraft Build
SpeedyVV
Hoping to be able to buy my gf's son (8 year old) a rig to play minecraft as cheaply as possible.
Playing Minecraft
As cheap as possible < £180 VAT Included
UK. Buying from scan.co.uk
Case (with PSU), CPU, Ram, Motherboard.
I have some HDDs lying around.
6) Will you be overclocking?
If possible or needed.
1080p max
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
None.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Both Ubuntu and Win 7 64-bit
Would this do?
MSI FM2-A55M-E33 AMD Socket FM2 Motherboard £35.46
AMD A-Series A6 5400K Black Edition FM2 CPU with Heat Sink Fan £42.65
CiT Knight Midi ATX Case 500W PSU £23.38
Corsair Memory 4GB DDR3 1333 Mhz CAS 9 Dual Channel Desktop £31.68
Total: £133.16
Or would I be better off buying a cheap GPU+CPU?
The PSU is my only concern, but there isn't much you can do with a sub-£180 budget.
If you decide to buy a video card in the future, pair it with the Corsair CX430.
That is a concern, but I am thinking that I can always buy a new PSU and replace later.
As long as it wont set my gf's house on fire and then she wanting to move in with me it should be ok. ;)
I can't help you with that last part... I mean, if you do too good of a job.... :D
The system specs look good to me too and so is the PSU - mainly because you're not looking to get a discrete GPU.
