roninblade
- Sep 22, 2004
Okey it seems that the bracket on the back of the hard drive that hold the SATA cable detachted and got stuck in the Sata connector, so i removed it and now the only way the drive will work is if the cable is supported up, i taped it and it seems to be working, however whenever i move it thats when it becomes a problem, so im asking so i try to try and send it in?
EDIT* I guess Western Digital is Smart and created Smart connect SATA cables, could that do the trick?*
