I'm building a server using a SuperMicro X8ST3-F motherboard, which accepts a single LGA 1366 socket CPU. I'd like to use ECC RAM, so I'd like to get a Xeon. Builds that I've looked at on the web use the Xeon W3550.
I'm a little worried about power usage. The W3550 is a quad-core, single 130W TDP. I don't mind spending a little more if I get that back in electricity savings in the next 6 years that this server will hopefully be in use.
My newbie questions:
Can I use a Xeon E5530 (80W TDP) instead, since the socket is the same?
Are the clock speeds comparable? That is, is a 2.4GHz E5530 faster than a 2.4GHz W3503?
