WilliamFred
- Feb 22, 2004
For reasons having to do with the placement of my monitor, I need an LCD with a good vertical viewing angle, particularly when seen from below. Unfortunately, I can only get a 17 inch LCD and most of those use TN screens. I understand that PVA, MVA and IPS have better viewing angles (especially vertical) than TN, but it is very difficult to ascertain which 17 inch LCDs are NOT TN. I think the EIZO 557 is a PVA, but I'm not sure about any of the others. (I've checked out the ones at Best Buy, Circuit City, etc. but they tend not to carry top of the line stuff). Does anybody have any advice on which 17 inch LCDs would most likely provide a good viewing angle from below, or at least know which ones are PVA, MVA or IPS?
Thank you
P.S. I also need one with built-in speakers, which makes my search just a bit harder.
Thank you
