Vertical GPU Bracket/mod options?
scgt1
I'm debating spinning my gpu on it's side in my Air 240 but it seems all the brackets available are for like 7 pci slots or are from MNPC Tech and take a massive amount of space up with how they mount. I would really like to keep my P/P H100I setup in from and there isn't much space left now as it is.
I was debating getting one of these and chopping the lower section off since there is only 4 pci expansion slots to a 240 Air. Then again I haven't shut down my computer and pulled my gpu to turn it and see if it would even mount with that type of bracket.
