geekcomputing
- Aug 30, 2004
Since the support at OCZ blows im coming here.
I flashed my Vertex to 1.10 following the guide on the site, it was successful and shows up in bios as 1.10 BUT i can not see the drive in windows.
I have tried taking out the CMOS battery w/ the power cable unplugged and then restarting but its the same. Tried running it in IDE mode.. same thing.
suggestion?
Also since the OCZ site is bunk i need to find the drivers to upgrade to 1.6
i have found the 1.5 and 1.6 but i need 1.10 to 1.40 anyone know of a place that would have them since the DAMN site does not (or if they do good luck finding them).
Thanks,
Austin
suggestion?
Thanks,
Austin
