Vertex 450 (128GB) - Disk I/O error
Discussion in 'SSDs & Data Storage' started by MrReplay, Feb 20, 2014.
  1. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    When I switched my PC on yesterday I got an error - I can't remember the exact error - after I few tries I decided to reinstalling Windows 7, the disk was showing as unallocated space & I tried installing but got some other kind of error (maybe I/O)
    After some Googling on my phone I got a command prompt off the install CD & tried:
    diskpart
    select disk
    clean all
    This threw an I/O error. I subsequently tried just clean which executed ok but it still wouldn't let me reinstall the OS. After this I booted into an Ubuntu live CD to try formatting it there but sudo fdisk -l but this wouldn't even display the disk?
    Is there anything else I can try here or am I wasting my time?
  2. /dev/null
    /dev/null [H]ardForum Junkie
    13,827
    Mar 31, 2001
    How about booting a linux live cd and using hdparm to secure erase it? I'm guessing you don't have anything on it you need....?
  3. zfsgeek
    zfsgeek n00b
    25
    Jan 31, 2014
    Robstar is spot on with it.
    Try to secure erase the drive first. Before (and perhaps after, if it completes successfully), you might want to check the SMART attributes for signs of wear.
  4. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    So I rebooted into an Ubuntu live cd; I noticed the disk is showing up in the BIOS screen but when I look in GParted it's not listed?
  5. drescherjm
    drescherjm [H]ardForum Junkie
    14,201
    Nov 19, 2008
    Look at it with hdparm, smartctl. fdisk.
  6. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    sudo fdisk -l doesn't show it, what commands should I use with hdparm?
  7. drescherjm
    14,201
    Nov 19, 2008
    If you do not see it in fdisk -l then it probably does not even have a device node. Maybe check your dmesg for any mention of problems with sda ...
  8. Lost-Benji
    Lost-Benji Limp Gawd
    321
    Jun 23, 2013
  9. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    Could you be more specific to what commands I should use?
  10. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    What do you mean check my commands?
    What should I be checking in BIOS / hardware config? Note that one day it was working, the next day I couldn't reinstall the OS - no BIOS settings were changed in between that time. I should also say that I tried resetting the BIOS defaults, which made no difference...
  11. drescherjm
    14,201
    Nov 19, 2008
    This is typical of SSD failure. I suspect you hit some type of controller failure or a firmware bug (and nothing at all to do with the NAND).
  12. drescherjm
    14,201
    Nov 19, 2008
    When you did fdisk -l did you see a missing device node? I mean did you have /dev/sda, /dev/sdb /dev/sdc ... or did you have one device missing from the middle? If you had a missing device node grep that from your dmesg
    For example if /dev/sdb was missing from your fdisk -l
    dmesg | grep sdb
    would show you just the kernel messages for /dev/sdb
  13. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    fdisk only shows the 2 other disks attached to my system, the OCZ isn't listed?
  14. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    Edit: I'll boot into the live disk again, hold on...
  15. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    Here's the output:
    sda is a 2TB data disk
    sde is a 160GB disk I've used to reinstall Win7 on
    the SSD isn't showing?
  16. drescherjm
    14,201
    Nov 19, 2008
    Is there more than sda and sde when you execute the following:
    Code:
    ls -al /dev/sd?
    Does this show anything other than sda and sde
    Code:
    dmesg | grep Attached
    Here is an example from my home pc:
    Code:
    jmd0 work # dmesg | grep Attached
    [    1.285419] scsi 0:0:0:0: Attached scsi generic sg0 type 0
    [    1.287568] sd 0:0:0:0: [sda] Attached SCSI disk
    [    1.771842] sd 1:0:0:0: Attached scsi generic sg1 type 0
    [    1.825793] sd 1:0:0:0: [sdb] Attached SCSI disk
    [    2.246637] sd 2:0:0:0: Attached scsi generic sg2 type 0
    [    2.266422] sd 2:0:0:0: [sdc] Attached SCSI disk
    [    2.483685] sd 6:0:0:0: Attached scsi generic sg3 type 0
    [    2.563292] sd 6:0:0:0: [sdd] Attached SCSI disk
    [    2.599633] sd 7:0:0:0: Attached scsi generic sg4 type 0
    [    2.634590] sd 7:0:0:0: [sde] Attached SCSI disk
    [    2.720195] sd 3:0:0:0: Attached scsi generic sg5 type 0
    [    2.754593] sd 3:0:0:0: [sdf] Attached SCSI disk
    [    3.193226] sd 4:0:0:0: Attached scsi generic sg6 type 0
    [    3.226541] sd 4:0:0:0: [sdg] Attached SCSI disk
    [    3.666237] sd 5:0:0:0: Attached scsi generic sg7 type 0
    [    3.702600] sd 5:0:0:0: [sdh] Attached SCSI disk
    [    4.049306] sd 9:0:0:0: Attached scsi generic sg8 type 0
    [    4.085084] sd 9:0:0:0: [sdi] Attached SCSI disk
  17. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    Code:
    ubuntu@ubuntu:~$ ls -al /dev/sd?
    brw-rw---- 1 root disk 8,  0 Feb 20 20:49 /dev/sda
    brw-rw---- 1 root disk 8, 16 Feb 20 20:49 /dev/sdb
    brw-rw---- 1 root disk 8, 64 Feb 20 20:49 /dev/sde
    I don't get an output for dmesg | grep Attached
  18. drescherjm
    14,201
    Nov 19, 2008
    Are you booting from a USB stick? sdb shows up there.
    Code:
    hdparm -I /dev/sdb
    smartctl --all /dev/sdb
  19. drescherjm
    14,201
    Nov 19, 2008
    I am running gentoo so there could be differences in the output during drive detection.
  20. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    I'm booting from a live CD..
  21. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    Is there anything else I could try here?
  22. drescherjm
    14,201
    Nov 19, 2008
    Did
    Code:
    hdparm -I /dev/sdb
    or
    Code:
    give you anything.
  23. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    Code:
    ubuntu@ubuntu:~$ sudo hdparm -I /dev/sdb
    /dev/sdb:
    ATA device, with non-removable media
    	Model Number:       OCZ-VERTEX450
    	Serial Number:      OCZ-57V17A23R739NJ86
    	Firmware Revision:  1.0
    	Transport:          Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
    Standards:
    	Supported: 8 7 6 5
    	Likely used: 8
    Configuration:
    	Logical		max	current
    	cylinders	16383	16383
    	heads		16	16
    	sectors/track	63	63
    	CHS current addressable sectors:   16514064
    	LBA    user addressable sectors:  250069680
    	LBA48  user addressable sectors:  250069680
    	Logical  Sector size:                   512 bytes
    	Physical Sector size:                   512 bytes
    	device size with M = 1024*1024:      122104 MBytes
    	device size with M = 1000*1000:      128035 MBytes (128 GB)
    	cache/buffer size  = unknown
    	Nominal Media Rotation Rate: Solid State Device
    Capabilities:
    	LBA, IORDY(can be disabled)
    	Queue depth: 32
    	Standby timer values: spec'd by Standard, no device specific minimum
    	R/W multiple sector transfer: Max = 1	Current = 1
    	DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
    	     Cycle time: min=120ns recommended=120ns
    	PIO: pio0 pio1 pio2 pio3 pio4
    	     Cycle time: no flow control=120ns  IORDY flow control=120ns
    Commands/features:
    	Enabled	Supported:
    	   *	SMART feature set
    	   *	Security Mode feature set
    	   *	Power Management feature set
    	   *	Write cache
    	   *	Look-ahead
    	   *	Host Protected Area feature set
    	   *	WRITE_BUFFER command
    	   *	READ_BUFFER command
    	   *	DOWNLOAD_MICROCODE
    	    	SET_MAX security extension
    	   *	48-bit Address feature set
    	   *	Device Configuration Overlay feature set
    	   *	Mandatory FLUSH_CACHE
    	   *	FLUSH_CACHE_EXT
    	   *	SMART self-test
    	   *	General Purpose Logging feature set
    	   *	64-bit World wide name
    	   *	Segmented DOWNLOAD_MICROCODE
    	   *	Gen1 signaling speed (1.5Gb/s)
    	   *	Gen2 signaling speed (3.0Gb/s)
    	   *	Gen3 signaling speed (6.0Gb/s)
    	   *	Native Command Queueing (NCQ)
    	   *	Host-initiated interface power management
    	   *	DMA Setup Auto-Activate optimization
    	   *	Software settings preservation
    	   *	Data Set Management TRIM supported (limit unknown)
    Security:
    	Master password revision code = 30688
    		supported
    		enabled
    		locked
    	not	frozen
    	not	expired: security count
    	not	supported: enhanced erase
    	Security level high
    Logical Unit WWN Device Identifier: 5e83a97632619308
    	NAA		: 5
    	IEEE OUI	: e83a97
    	Unique ID	: 632619308
    Checksum: correct
    Code:
    ubuntu@ubuntu:~$ sudo smartctl --all /dev/sdb
    smartctl 6.2 2013-04-20 r3812 [x86_64-linux-3.11.0-12-generic] (local build)
    Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
    === START OF INFORMATION SECTION ===
    Device Model:     OCZ-VERTEX450
    LU WWN Device Id: 5 e83a97 632619308
    Firmware Version: 1.0
    User Capacity:    128,035,676,160 bytes [128 GB]
    Sector Size:      512 bytes logical/physical
    Device is:        Not in smartctl database [for details use: -P showall]
    ATA Version is:   ATA8-ACS (minor revision not indicated)
    SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
    Local Time is:    Fri Feb 21 15:07:41 2014 UTC
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    General SMART Values:
    Offline data collection status:  (0x00)	Offline data collection activity
    					was never started.
    					Auto Offline Data Collection: Disabled.
    Self-test execution status:      (   0)	The previous self-test routine completed
    					without error or no self-test has ever
    					been run.
    Total time to complete Offline
    data collection: 		(    0) seconds.
    capabilities: 			 (0x1d) SMART execute Offline immediate.
    					No Auto Offline data collection support.
    					Abort Offline collection upon new
    					command.
    					Offline surface scan supported.
    					Self-test supported.
    					No Conveyance Self-test supported.
    					No Selective Self-test supported.
    SMART capabilities:            (0x0003)	Saves SMART data before entering
    					power-saving mode.
    					Supports SMART auto save timer.
    Error logging capability:        (0x00)	Error logging NOT supported.
    					General Purpose Logging supported.
    Short self-test routine
    recommended polling time: 	 (   0) minutes.
    Extended self-test routine
    SMART Attributes Data Structure revision number: 18
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
      5 Reallocated_Sector_Ct   0x0000   216   216   000    Old_age   Offline      -       63960 (0 23540)
      9 Power_On_Hours          0x0000   100   100   000    Old_age   Offline      -       2066
     12 Power_Cycle_Count       0x0000   100   100   000    Old_age   Offline      -       234
    171 Unknown_Attribute       0x0000   000   000   000    Old_age   Offline      -       0
    174 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       3318181484
    195 Hardware_ECC_Recovered  0x0000   100   100   000    Old_age   Offline      -       3649066674
    196 Reallocated_Event_Count 0x0000   100   100   000    Old_age   Offline      -       63544 (0 59146)
    197 Current_Pending_Sector  0x0000   100   100   000    Old_age   Offline      -       2607393518
    208 Unknown_SSD_Attribute   0x0000   100   100   000    Old_age   Offline      -       59
    210 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       58
    233 Media_Wearout_Indicator 0x0000   097   097   000    Old_age   Offline      -       97
    241 Total_LBAs_Written      0x0000   100   100   000    Old_age   Offline      -       1814
    242 Total_LBAs_Read         0x0000   100   100   000    Old_age   Offline      -       1516
    249 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       110778826833771
    Warning! SMART ATA Error Log Structure error: invalid SMART checksum.
    SMART Error Log Version: 1
    No Errors Logged
    Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
    SMART Self-test log structure revision number 1
    No self-tests have been logged.  [To run self-tests, use: smartctl -t]
    Selective Self-tests/Logging not supported
  24. drescherjm
    14,201
    Nov 19, 2008
    I was going to point you to a step by step secure erase procedure using hdparm however the info you posted indicates that the drive its locked. I believe if you don't know the unlock password you can not continue with a secure erase.
  25. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    Do you have any idea how it got locked?
  26. drescherjm
    14,201
    Nov 19, 2008
    You need to know the password. I am not sure if there is a default password for your SSD or something else is in play. Hopefully someone else knows. I have only seen drives that were not locked when I tried the secure erase.
    BTW: Here are the instructions to secure erase. If you can unlock the drive you can try this (remember to use /dev/sdb instead of /dev/sdx):
    http://tinyapps.org/docs/wipe_drives_hdparm.html
  27. MrReplay
    MrReplay n00b
    41
    Mar 24, 2012
    A bit of Googling shows people with similar problems; writing a support ticket to OCZ now
    Thanks for all your help drescherjm :cool:
  28. drescherjm
    14,201
    Nov 19, 2008
    Here are some possibilities I can think of at the moment: Could be the BIOS. Could be the firmware on the drive autolocking when it has problems. The drive could be locked with soem default password. Could be a virus set the password.
  29. drescherjm
    14,201
    Nov 19, 2008
    You are welcome.
