Verifying DMI Pool data.... going insane...
Wihl
I'm having this problem with my computer... =/
Abit kv8 pro
AMD64 3000+
Kingston pc3200 512 mb
9800 pro
Anyway, i when i start the computer it stops at "Verifying DMI pool data" for like 10 minutes, it then continues and goes into windows and everything.. i dont know what to do =( The cables are ok/installed correctly. I haven't cleared the CMOS yet but i will... Any solutions? =/
EDIT: This computer is brand new - i built it today. BUT the harddrive isn't new. Its a Seagate barracuda V... I had problems with it on my other computer but nothing like this. (It wouldn't run DMA on my other comp. only PIO-mode.. really annoying...)
i bought a new harddrive, works great.. i use the crap hdd as slave.
