Verify Com Ports
raksasas
Can someone verify these as to which com port they pertain to?
3F8/IRQ4
2F8/IRQ3
3E8/IRQ7
3E8/IRQ5
3F8/IRQ4 = COM1
2F8/IRQ3 = COM2
3E8/IRQ7 = COM3
2E8/IRQ5 = COM4
These are by default though and can be modified in the BIOS
Here are some standards...
IRQ 0 Timer channel 0 (May mean "no interrupt". See below.)
IRQ 1 Keyboard
IRQ 2 Cascade for controller 2
IRQ 3 Serial port 2
IRQ 4 Serial port 1
IRQ 5 Parallel port 2, Sound card
IRQ 6 Floppy diskette
IRQ 7 Parallel port 1
IRQ 8 Real-time clock
IRQ 9 Redirected to IRQ2
IRQ 10 not assigned
IRQ 11 not assigned
IRQ 12 not assigned
IRQ 13 Math co-processor
IRQ 14 Hard disk controller 1
IRQ 15 Hard disk controller 2
Only problem is you can set any memory range and irq at boot up, but I dont think people have done that for years. It should match up correctly. In windows you can go to device manage -> Ports then select a port and go to its property dialog's resource tab and it should tell you what irq and mem range is being used.
