verify budget gaming build
boonani
Budget build for friend
Gaming- Starcraft2, Diablo3, Aion
About $600 yes both tax and shipping included. Cheapest route as possible.
3) Where do you live?
NJ
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything.
Nothing
6) Will you be overclocking?
Very likely
22inch" LCD
This weekend
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
10) Do you already have a legit and reusable/transferable OS key/license?
Gonna get Windows 7.
What I specced for him so far.
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM - $74.99
Combo- $125.99
AMD Athlon II X2 245 Regor 2.9GHz Socket AM3 65W Dual-Core Processor Model ADX245OCGQBOX - Retail
GIGABYTE GA-MA785GM-US2H AM3/AM2+/AM2 AMD 785G HDMI Micro ATX AMD Motherboard - Retail
Combo- $209.98
SAPPHIRE 100279-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Retail
Combo-$149.90
Antec TruePower New TP-650 650W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE ... - Retail
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - Retail
SAMSUNG DVD Burner Black SATA Model SH-S223L LightScribe Support - OEM- $31.99
Build looks good but you should know that card and board, most of the SATA ports will be blocked by the video card.
also you will need a aftermarket HSF for overclocking, if you are going pass 3.5 GHz. I would suggest Coolermaster Hyper 212+.
if your budget will allow, this would be a better combo for the money Gigabyte 770T and x3 720
Yeah I was looking at the build and swapped couple stuff around.
Combo -$124.94
Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified ... - Retail
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Retail - $64.99
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM -$54.99
Combo- $178.99
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard - Retail
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor Model HDZ720WFGIBOX - Retail
I think that looks like a solid build. Only missing the graphics card. He'll be on a 19" but plans on buying a 22inch in couple months then upgrade graphics card in a year or so.
Need help choosing. Any explanation would be great.
XFX HD-485X-YDFC Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail - $114.99
XFX HD-485X-ZDFC Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail - $124.99
XFX HD-487A-ZWFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail - $144.99
-You need DDR3 memory for 770T. Suggested are G.Skill DDR3 4 GB 1600 Ripjaws
-4870 1 GB for 22" display
Looks like shiro has you covered. Don't forget to post pics!
Oh, and if you can, switch to a 640GB HDD, since it'll be slightly faster than that 500GB.
