TechLarry
RIP [H] Brother - June 1, 2022
- Aug 9, 2005
I'm using RoboCopy to copy corporate Windows 7 images to USB keys for distribution to field tech's.
The problem is, there is no general consensus on the net as to whether RoboCopy verifies it's copies or not. The question is asked a lot, but the best answer I've seen is still a guess by someone. There is no command line option for it, which seems to make people assume it does it by default.
I need a separate utility that can do a CRC or other check between the source folder and the built USB key for errors/differences.
Everything is being done under Windows 7 Pro or Ult.
