Verbatim portable hd
brysig228
i tried to install this to get some files from it but my computer wont install it what so ever. i'm running vista 64bit. i'm guessing that is why cuz i installed it with no problem with the vista 32bit. is there a way i can install this on my 64 bit system?
thanks
Install? Like in bundled software?
You don't need any software to be able to use the drive in a normal fashion, unless you want to use some sort of encryption or data security package that would entail the use of software.
Just plug it in and go; if you don't see it immediately in My Computer, go to Disk Management and format the drive.
i don't even see the drive at all to format besides i can't format it cuz there are files in it that i need to copy. i already look at My Computer and Disk Management and no drive..
