I am in the process of turning an old boiler room into a network closet. I have a chimney port that I want to use to vent out the heat from the switches and servers.
Has anyone done this?
Do I need to worry about chimney pressure? There is nothing else using this chimney.
What about heat from the outside? Will it soak in?
I am going to have it cleaned and capped with a wire mesh style cap.
