Velocity Micro Second Try - Mixed
I received my second Velocity Micro computer today, after the first got damaged. Here is a thread about that:
http://www.hardforum.com/showthread.php?t=1095842
System summary:
LXe-W Black Signature Case
550 Watt Antec True Power 2.0
Asus P5N32-SLI SE Deluxe motherboard
Intel Core 2 E6600
LiquiCool 3 Advanced Thermal Electric Cooling
2048MB Corsair Electric Cooling
256MB eVGA 7900 GT
Soundblaster X-Fi Extreme Music
The second computer arrived about a month after the first came damaged. (Actually about 28 days give or take). That included a week of waiting for VM to have UPS to verify damage, then another 2-3 weeks for VM to rebuild the system.
Needless to say, I was pretty concerned about the delivery of the 2nd computer. My wife called when it arrived and said the outside box was dinged up a bit, and something was rattling inside the computer. It turned out that one of the drive bay covers had become dislodged and was inside of the case. This is the second VM computer that I've had to open and attempt fixing before even turning on. UPS really sucks, and maybe VM should put more padding in the boxes.
Everything else looked fine though, and there was no other obvious damaged to the case, and all the cards were seated properly. VM upgraded my $200 water cooling option with the new $160 cooling system that came on in the meantime. I was excited, because I figured it'd be an upgrade and quieter then the original water cooling system. My main reason for spending the extra money was after talking to VM sales, and finding out that the Water cooling system was quieter then the normal CPU fans they installed. I didn't think to ask if the new thermal electric system was quieter, as I assumed it was. (Why put a louder system in when you don't officially support overclocking?)
So I plugged in the system and turned it on. The system came on, but was very loud. I figured that most systems start loud with fan noise for a quick cool off, but then quiet down. My previous Dell XPS did this. Unfortunately, the new VM never quiets down. It seems that the thermal electric cooling is quite loud all the time, maintaining a very constant noise. For instance, in every other computer I've owned, the video card when running a game, or 3dmark, is always the loudest component. With the new VM though, I can not hear the video card (7900 GT). When the system is running a game, or just idle, the system is loud. Louder then any other computer I've heard.
Another minor disappointment is that while the speakers worked and played normal Windows sounds, the Creative XiFi's control panel wasn't installed. That meant I had to install the software before putting the card into gaming mode to enable the better EAX support. Just a minor nitpick, but all the Nero software was installed, so why not the Creative control panel? I never heard back why this wasn't installed previously, or on this machine.
After getting the computer on and playing for a bit, I launched 3dmark06. This time the full professional version was on the system, thanks VM. I setup 3dmark06 to loop and left the room. When I came back an hour later, the computer had rebooted. At this point, after putting the latest drivers on the machine, I can not get 3dmark06 to run for more then an hour or two. I tried leaving the system on overnight w/ the 3dmark06 software running, but when I woke up at 5am the machine had rebooted, and the fans sounded extremely stressed, so I immediately shutdown.
I've tried some other tests sparingly so far, like Prime95 and Super PI. However, after hearing the sound from the computer after it being on all night, I'm very hesitant to leave the system on overnight again. The CPU temp program I have is also reporting both cores at 70 degrees Celsius w/ the combo of Prime95 and Super Pi, which seems to hot.
Through the process though, VM's support has been very good to excellent. I have been able to reach Chris and Heather from VM fairly often. I am waiting for them to reply to emails I sent over the weekend, but assume today may be a holiday for them.
Right now, the computer is as fast as I'd hoped, and functional, but I'm concerned about long time gaming, and casual use. I'm skeptical about stability since 3dmark06 won't run for more then an hour or two. I don't want to get caught up into a long gaming session to see a reboot. I'm also skeptical that the system can be left on overnight safely when working on something. My office gets very warm in the summer as well, so I'm hopeful the system will be fine then.
Heather suggested running 3dmark05 over the weekend, but the Pro version which I bought doesn't loop. Hopefully she can give me another good test. Chris hopefully will respond on the fan noise. I will call if I don't hear from them by tomorrow.
One other niggle, is that even though I didn't receive a functional computer for over two months (including the first damaged machine), VM definitely was on the ball with payments, as I was responsible for paying as soon as I ordered, not when the system was delivered. I feel a bit disappointed by this, as I'm sure any payment delay from me caused by the UPS' damage on the first one was probably covered by UPS insurance. I'm not sure though, just a guess.
Right now, I'm left with the following issues:
- very loud (louder then videocard) fan noise that is constantly on, and at times sounds strained. If the cooling system turns out to just be louder then 7900GT, then I will most likely strip it out and find a quieter solution on Newegg, and recommend against others getting it. The previous water cooling system was much quieter, and caused the 7900GT to be the loudest part of the machine only when gaming.
- 3dmark06 is not stable when running on the system
- warranty coverage if the cooling system is modified
My current thoughts on the computer is that I am more impressed with the personel in the company and their ability to respond then I am with the shipping and computer itself. I'm fairly confident that it'll all work out though. My previous computer, a Dell XPS probably had lousy support. I never had to experience it though, as it came stable out of the box and worked for years. I bought VM to have the great service behind the computer, and unfortunately I have to use it, whether VM's or UPS's problem.
Reader's Digest Summary -
- Great support from VM, especially Chris and Heather
- UPS is a disgrace
- "Rushed" rebuild off VM machine took 3+ weeks
- Second machine is very fast, but very loud, and unstable. Overall I'm not impressed, and I probably will have to install a quieter cooling system or surf the web on another machine.
Questions for others:
- what part of your system is the loudest? CPU cooling, case fans, or video card?
- is it unreasonable to want 3dmark06 to run over night?
I am very hopeful that I need to somehow reseat the new cooling system to quiet it down, and potentially another small fix to get 3dmark06 to run stably overnight. If I can get these two things going (a quiet and stable system), then it'll be just about the perfect computer backed by great support. Otherwise I don't know.
Scott
System summary:
Intel Core 2 E6600
256MB eVGA 7900 GT
- UPS is a disgrace
Scott
