So, I went out and got two 300GB WD Velociraptors from newegg. I of course planned to use RAID 0 on these drives, but now I have a possible problem. After installing Vista(64) and then installing everything my old RAID had, I find that my speeds on reading still seem about the same. Previously I had 2 WD Caviar SE16 250GB sata II hard drives in RAID 0 and in comparison, don't seem much slower now compared to these. I bought these paying about 4 times as much (space wise, only about ~$55 for a 320GB HDD), to see very little improvement. I know these drives in relation to speed are not an incredible amount faster (7200 VS 10,000), but I believed that with the density, and the speed mixed that these speeds would be a little more satisfying. I have both launched and tested these drives as well as use HD tune 2.55 on them (will post results in a second). Overall I see the speeds on HD tune are a bit faster but there are also problems on there with a large amount of dips. The disappointing speeds with the more than "silent" acoustics (these things do grind a bit when it is reading or writing a decent amount) all seem to point that either there is a problem with the drives, my RAID controller, or the drives are just not as great as everyone has said.
HD tune results:
As you see there are constant dips in this test. From this it makes me think only one of the drives is under-performing or something along those lines. What do you guys all think? Does this look like a bad hard drive, controller, etc....
Here are my specs:
MSI K9A2 Platinum (Using the promise controller for RAID 0)
AMD 9850BE @ 3.0GHz (air)
2 X 2 GB Mushkin 800MHz
2 X 300GB WD Velociraptors Sata II
1 X 500GB WD Caviar Sata II
3 X DVD-RW (2 LG, 1 Lite-On) Sata II
Rosewill 750W power supply
Cooler Master Stacker 830 Evolution
(I know most of that hardware doesn't mean anything but I decided to post it so I can just copy and paste into my signature ^^).
Anyways, any comments is appreciated a lot. At this point I am considering just sending these back to newegg and getting two 1TB drives for about half the price and just RAIDing those with 0 and see how those go.
Sorry for the long post but I just wanted to be as detailed as needed so no one needs to ask for more information.
HD tune results:
Here are my specs:
