VelociRaptor 600GB Help?
get the cheaper one as they're both the same model.
the 600GB comes in 3.5" or 2.5" bare.
both drives though at 2.5" just the 3.5" form factor has the icepack cooler around a 2.5" drive.
Maybe this is just pointing out the obvious, but I'm guessing the one in the second link (model ending in -NRSN) is just an older revision of the same drive. The specs look the same between the two, and the only thing I can find about the -NRSN drive on the WD website is documentation from August 2010. The -HLHX drive, on the other hand, is all over the WD website, so I'm guessing it's the current revision, which might explain why it's more expensive than the -NRSN drive even though the -NRSN is retail and the -HLHX is OEM.
If you really want to know the exact differences you might want to contact WD directly.
