veiwsonic VX2268WM
Dark_Captain
so im a avid gamer...1.6 and sc2 are my choice and ive been tryingto find a nice 120hz monitor with out breaking the bank and the samsung 2233rz was the best to get BUT they dont make it anymore and i dont want a used monitor and i found the VX2268WM which im told is a samsung panel anyone have thoughts on it?sorry my typing is bad im tired and its early
ViewSonic VX2268wm are better than 2233rz IMO, I bought both and kept ViewSonic and returned the Samsung. That was mainly due to the inaccurate/unnatural color tone of the 2233rz, at least my sample was far too bluish that couldn't be completely fixed even with blue set to 0 and green and red sliders set a lot higher also the stand on 2233rz was too low for my liking. Couldn't notice any difference in input lag but the ViewSonic appeared to have slightly less ghosting/blur but yea I'm not completely sure on that as both being 120Hz the ghosting isn't any problem anyway. VX2268wm seems to have more backlight bleed than 2233rz but as usual it varies from sample to sample, lowering the brightness should remove it almost completely.
