Vega 56, non-blower cards?
Discussion in 'AMD Flavor' started by c3k, Aug 11, 2018.
  1. c3k
    c3k 2[H]4U
    2,079
    Sep 8, 2007
    Sure, Asus Strix has an aftermarket cooling solution. Anyone else?
    crickets...
    I'm looking for a 2560x1440 gaming AMD card. Vega56 would fit the bill. I'd like something other than the reference cooler, but there seems to be a dearth of designs.
    Any ideas???
  2. Krenum
    Krenum [H]ardForum Junkie
    15,263
    Apr 29, 2005
    c3k likes this.
  3. c3k
    c3k 2[H]4U
    2,079
    Sep 8, 2007
    Krenum likes this.
  4. ccityinstaller
    ccityinstaller 2[H]4U
    3,802
    Feb 23, 2007
    It is unfortunate that there are so few aftermarket cards, and I say that as a guy with 7 Water-cooled VEGAs. The reference designed cards are built like tanks! They are excellent for WC'ing, but not so great for sir cooling.
    I have seen Vega 64s below $500 new. Set up a Now in stock alert and you should be good to snag one.
    c3k likes this.
  5. primetime
    primetime [H]ardness Supreme
    5,519
    Aug 17, 2005
    man i want to upgrade as well.....the Asus triple fan cards always catch my attention https://www.newegg.com/Product/Prod...a&cm_sp=&AID=10440897&PID=3891137&SID=rewrite
    prices seem reasonable compared to 3 months ago
  6. LigTasm
    LigTasm [H]ardness Supreme
    4,909
    Jul 29, 2011
    Don't get the pulse. Its a Nano PCB which means zero overclocking and you won't be able to flash it without bricking it.
  7. primetime
    5,519
    Aug 17, 2005
    have you any info on the asus models?
  8. LigTasm
    4,909
    Jul 29, 2011
    Asus and the Sapphire full size (nitro?) cards are very good, supposedly the Gigabyte had some issues but it seems pretty beefy as well. TBH the reference PCB is quite good as well so even the powercolor cards that slap 3-fan shrouds on them work well.
    Just bear in mind that these cards put out a massive amount of heat, my V56 with the Raijintek air cooler on it turned my case into a furnace. After playing games for more than an hour or two literally everything in there was 90C because I had my fans set of silence. Kinda defeated the purpose of getting rid of the blower so I put it under water.
    My only advice is to avoid the Nano PCB cards, they were supposed to be used for a card like the Nano Fury but I guess they never bothered or couldn't get the TDP under control so now you have these huge heatsinks strapped to half size cards with a mediocre VRM that are as locked down as you can get.
    Araxie and Ocellaris like this.
  9. primetime
    5,519
    Aug 17, 2005
    Oh
    i got ya....the tiny nano versions! ......let me ask ya......the vega56 really put out more heat than my rx580? I mean i guess it makes sense that it would....Although i probably try and tweak it with lowering the voltage to tame the power usage
  10. LigTasm
    4,909
    Jul 29, 2011
    Two RX580 overclocked in crossfire might do about the same... in reality its a 250W+ TDP card. People tend to undervolt them to get them to be more manageable.
  11. c3k
    c3k 2[H]4U
    2,079
    Sep 8, 2007
    Asus Strix purchased and enrouteā€¦
    Thanks.
  12. primetime
    5,519
    Aug 17, 2005
    your gonna make me order one to go with my new improved setup lol
  13. c3k
    c3k 2[H]4U
    2,079
    Sep 8, 2007
    I got a nice surprise. I ordered the Asus Strix through Newegg for $489 and was happily surprised to get an instant $150 AMD gift card...which was taken off my invoice.
    So, yeah: jump on it. An Asus Strix Vega 56 for ~$350 out of pocket.
    deruberhanyok and primetime like this.
  14. primetime
    5,519
    Aug 17, 2005
    did yours look like this during checkout?
  15. c3k
    c3k 2[H]4U
    2,079
    Sep 8, 2007
    Yeah...and then later I got a new invoice...reflecting the 489 minus 150.
    That first one had me puzzled and I shrugged. The second one made me smile.
  16. primetime
    5,519
    Aug 17, 2005
    It apearsa to some kind of Amd instant rebate for just that asus model...instead of game codes......I'll probably get one at that price
  17. BugginOuT
    BugginOuT Limp Gawd
    441
    May 14, 2008
    Why is it showing up as $639.99 for 2 items? Shouldn't it just be $489.99? My grand total comes out to $522.45, nowhere near that price of $350
  18. c3k
    c3k 2[H]4U
    2,079
    Sep 8, 2007
    I'm pretty happy, as you could imagine, to get this card for this price. I'm building a new rig (not yet in sig), based around an AMD 2700x. This card and a 2560x1440 screen will fill the build nicely. Another Vega 56 card at this price would be nice to replace an R9 390 for the same screen resolution.
  19. primetime
    5,519
    Aug 17, 2005
    im in same boat and am thinking it does the correct math AFTER checkout....of course if it doesnt just cancel before it ships....(or dont open it for sure)
    Edit: worked for me just now Total Amount: $346.98
    BUT it ALSO shows a pending fee of 150 dollars in addition to the 346.....Maybe its just a pending glitch that gets dropped?
    08/16/2018 03:31:40 ($346.98) $XXX.XXX Pending - WWW.NEWEGG.COM 800-390-1119 CAUS
    08/16/2018 03:31:38 ($150.00) $XXX.XXX Pending - WWW.NEWEGG.COM 800-390-1119 CAUS
  20. primetime
    5,519
    Aug 17, 2005
    yep i had to call and cancel mine on principle alone lol....if i had known it was x amount from the start i would have kept the order....but trust me they hit you for another 150 charge for the FREE games lol
  21. deruberhanyok
    deruberhanyok [H]ard|Gawd
    1,347
    Aug 22, 2004
    Wondering if AMD might respond to RTX with price drops. I don't see Vega competing very well with a 2070 at $500, but if those "instant rebates" are hinting at a future new norm of $350ish, it might keep them a viable option.
