Vega 56 flash to 64 issues.
Archaea
I flashed my Vega 56 PowerColor and Sapphire cards to Vega 64 stock bios tonight.
I'm encountering issues now. Star Wars Battlefront runs at 10FPS in crossfire. I'm getting roughly a single Vega 64 score in Firestrike even when Crossfire on the two cards is enabled. The cards worked much better before I flashed them.
This is the bios I used: It's just a generic AMD Stock Vega 64 BIOS.
https://www.techpowerup.com/vgabios/194441/amd-rxvega64-8176-170719
I used the same BIOS on both cards --- could that be an issue? I flashed the left most switch position as suggested. The cards are working - just not working well.
Any suggestions?
did you check if your cards are throttling?
Are their voltage differences between the 56 and 64 drivers? If there are differences there is a good chance your cards are throttling.
Also try one card at a time and see what happens then.
