As the STICKY on the AMD cpu forum (Amd specification thread) it says that AMD XP`s
AMD Athlon XP 2800+
Core: Barton
Socket: Socket A
Operating Frequency: 2.08GHz
FSB: 333MHz
Cache: L1/64K+64K; L2/512K
Voltage: 1.5V
Wattage: 55W
Process: 0.13Micron
Vcore is supposed to be 1.5v.
IN my Bios (Via Kt6V-LSR) mobo its says default bios is 1.65v , I got the volcano 9 hsf and i think thats why my temp are high (51c right now)
When i lower it to 1.5v, it wont boot up to windows, only at 1.55 , Is there any explanation to that?
And to oveclock it, my goal os 2.2ghz (3200+ speeds) should i lower the default Multi to 10 and raise the default 166mhz fsb to 200mhz Or i should simply keep the same multi (12.5x default) and raise it to 176mhz (my ram ram is a mix of 2 512mb stick of del-ol cheapy Samsung ram and Nanya^!)
Thank you!
AMD Athlon XP 2800+
Core: Barton
Socket: Socket A
FSB: 333MHz
Voltage: 1.5V
Wattage: 55W
Process: 0.13Micron
Thank you!
