To get accurate voltages, don't use software, period.Unknown-One said:Yea, don't use CPUz for reading voltages. Try SpeedFan instead, or even the voltage readings in the BIOS themselves. If all else fails, you could even break out the trusty multimeter.
Every CPU will do that reading from software. Mine jumps around in the second and third digits too. It's actually normal, as those minute changes in voltage are caused by the CPU's current draw, i.e. workload.Boyo said:How reliable is CPU-z for checking your vcore. For some reason, and I don't know if this is normal, but my vcore constantly jumps from 1.424 to 1.456 to 1.472. It's all over the place. Is my mobo or OC unstable?
