vcool is v. cool!
mmynett
Just bought an antec vcool intake fan for my following rig:
Abit AA8XE
Intel 3.2 @ 3.85 P4 540j
XP-90 HSF
1gb OCZ DDR2 533 Value ram
3dconnect x800xl @ 453core 567mem
460W Akasa UQuiet PSU
Here's the temps before i installed the fan:
Here's the temps after i installed the vcool:
My graphics card temps dropped 5c, also my cpu\sys temps also dropped 4c as well.
Gotta be happy with that!
Nice drop in your temps.:) Not sure how it would help cpu temp being an intake..you msut not have much airflow. I use one of those 2 fan, blue led deals under my card in work rig. Never really checked it it helped much, I assume it did some, as the air must help cool the mem on the vid card.
Yeah airflow was not too good before, my case only has room for 1 80mm case fan at the front!
Was thinking of getting one of those but it didn't really seem that effective last time I checked. Guess I should read a few reviews and see.
The one slot PCI fans dont do much, but the two slot fans (Like the one linked) move a LOT of air :eek:
Yeah had a one slot fan that recently died, hence a replacement! That did'nt seem to do too much temp wise, but the vcool shifts alot of air into the case.
I orientated the 80mm case fan at the front to blow air out.... not ideal but i don't want to buy another case, with better cooling options, just yet.
