Child of Wonder
- May 22, 2006
In my lab I have 3 domain controllers: 2 running Windows 2012 and a brand new one running 2012 R2. Last night I decided I wanted to get all of them up to 2012 R2 so I moved the FSMO and Schema master roles to the existing 2012 R2 machine, demoted the first DC, removed it from the domain, and proceeded to rebuild it.
Right after the demotion I realized my DNS wasn't working. Strange because while the DC I just took down was usually the primary DNS server for my network, everything should use the secondary DNS server. Then I saw my vCenter client showed everything as inaccessible and it eventually crashed. I couldn't reconnect to vCenter anymore and figured it was a DNS problem.
I figured once I got AD and DNS up and running on that DC again, everything would be fine. So I got the DC rebuilt and reconfigured and attempted to log into the vCenter client again. No dice. Tried the IP but got the same result. "Unable to connect to remote server." Then I tried the Web client and while I could get in with my AD creds, I was greeted with an empty inventory and the message:
"Could not connect to one or more vCenter Server systems: https://192.168.0.13:443/sdk"
Looking at my vCenter server appliance's config page, I see that the vCenter service is stopped. I reboot the VCSA but no go. I manually start the service and while it appears to run, within a few minutes it shows as stopped again. I removed and re-added my domain as an identity source in SSO, but no go.
I'm not finding any help in the KB or forums. Seems I've broken new ground! If I wasn't using distributed switches in my cluster, this wouldn't be a big deal since I could just build the VCSA again. I do have a backup of my VDS so I could still do that, but would rather troubleshoot and fix the issue, if possible. Anyone seen something like this?
