So we're soon'ish going to be migrating a bunch of machines to Java 7.
We found a script online to uninstall all version of Java except a specified version.
While the script works, the downside is that if Java is in use when it's run the computer will forcefully reboot.
We need to be able to kill the Java processes (java.exe, jqs.exe, etc) prior to the uninstall.
Here's the code we found, with some minor modifications in the Sub KillProc() and an additioanl call to a KillJava function which I created and will post next.
Function KillJava()
There's a lot of commented stuff due to a bunch of trial and error.
Where I'm currently at:
I created a script with just the Sub KillProc() and Function KillJava()
I log on to a machine with my credentials, open up IE and a Java app.
I then run the command prompt as a different administrative user, and run the script. It successfully kills the IE process and all Java processes.
We deploy our software with LANDesk, which runs the VBS in the LocalSystem account. When deployed via LANDesk, it still forcefully reboots the machine and none of the processes get killed.
Help?
Code:
'# Galen Dobbs - 12:42 19/03/2009
'# Uninstalls all but the chosen version of Java Runtime.
'# Based on a script by 'Daz' from the Appdeploy.com message boards.
'# Based on a script by 'muaddip' from the Appdeploy.com message boards.
'# http://www.appdeploy.com/messageboards/tm.asp?m=29809
Option Explicit
Dim wshShell, fso, strLogFile, ts, strTempDir, strTempISS, strUnString, tsIn, blFound
Dim strUninstLine, CLSID, search5, search6, search7, strJRE1, strDisplayName, strDisplayVersion
Dim strPublisher, strUninstallString, strJREUninstallString, strJREDisplayName
Dim search1, search2, search3, search4, strJREUninstallStringNEW, ret, strUninstCMD
Dim tsISS, strSetupexe, qVal, strComputername, strCurrentVersion, searchCurVer
'Change this to match the version that you don't want to have it uninstall
strCurrentVersion = "Java(TM) 7 Update 15"
qVal = 0
Set wshShell = CreateObject("WScript.Shell")
Set fso = CreateObject("Scripting.FileSystemObject")
strComputername = wshShell.ExpandEnvironmentStrings("%COMPUTERNAME%")
If Not fso.FolderExists("C:\Logs") Then fso.CreateFolder("C:\Logs")
strLogFile = "C:\Logs\Java_Uninstall_" & strComputername & ".log"
Set ts = fso.OpenTextFile(strLogFile, 8, True)
ts.WriteLine String(80, "_")
ts.WriteLine String(80, "¯")
ts.WriteLine Now() & " - Java Runtime(s) uninstallation"
ts.WriteLine String(80, "_") & vbCrlf
'# Generate Registry extracts from 'Uninstall' keys.
PreFlight()
'# Kill Java Processes
KillProc()
'# Kill IE or Firefox instances
KillJava()
strTempDir = wshShell.ExpandEnvironmentStrings("%temp%")
strTempISS = strTempDir & "\iss"
strUnString = " -s -a /s /f1"
Set tsIn = fso.OpenTextFile(strTempDir & "\uninstall.tmp", 1)
If Not fso.FolderExists(strTempISS) Then fso.CreateFolder(strTempISS)
blFound = False
Do While Not tsIn.AtEndOfStream
strUninstLine = tsIn.ReadLine
CLSID = Mid(strUninstLine, 73, 38)
search5 = Instr(strUninstLine, "JRE 1")
search6 = Instr(strUninstLine, "]")
If search5 > 0 AND search6 > 0 Then
strJRE1 = Replace(Mid(strUninstLine, search5, search6),"]","")
End If
On Error Resume Next
strDisplayName = wshShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\" & CLSID & "\DisplayName")
strDisplayVersion = wshShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\" & CLSID & "\DisplayVersion")
strPublisher = wshShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\" & CLSID & "\Publisher")
strUninstallString = wshShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\" & CLSID & "\UninstallString")
strJREUninstallString = wshShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\" & strJRE1 & "\UninstallString")
strJREDisplayName = wshShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\" & strJRE1 & "\DisplayName")
On Error Goto 0
'Search for presence of Java and Sun in DisplayName and Publisher
search1 = Instr(1, strDisplayName, "Java", 1)
search2 = Instr(1, strPublisher, "Sun", 1)
search3 = Instr(1, strDisplayName, "J2SE", 1)
search4 = Instr(1, strUninstallString, "setup.exe", 1)
search7 = InStr(1, strDisplayName, "Development", 1) + InStr(1, strDisplayName, "Java DB", 1)
'Make sure it is not the current version
searchCurVer = InStr(1, strDisplayName, strCurrentVersion, 1)
If searchCurVer > 0 Then
ts.WriteLine Now() & " - Current Version: " & strDisplayName & " found, leaving it alone."
ElseIf strJREUninstallString <> "" Then
blFound = True
'# JRE 1 found
strJREUninstallStringNEW = Replace(strJREUninstallString," -f"," -s -a /s /f")
ts.WriteLine Now() & " - " & strJREDisplayName
ts.WriteLine Now() & " - Uninstall String sent: " & strJREUninstallStringNEW
ret = wshShell.Run(strJREUninstallStringNEW , 0, True)
ts.WriteLine Now() & " - Return: " & ret
If ret <> 0 And ret <> 3010 Then qVal = 1
ElseIf search7 = 0 And search1 > 0 Or search3 > 0 And search2 > 0 Then
blFound = True
strUninstCMD = "msiexec.exe /x " & CLSID & " /norestart /qn REBOOT=ReallySuppress"
If search4 > 0 Then
'# Old InstallShield setup found
Set tsISS = fso.OpenTextFile(strTempISS & "\" & CLSID & ".iss", 2, True)
'Create Response file for any Java Version
tsISS.WriteLine "[InstallShield Silent]"
tsISS.WriteLine "Version=v6.00.000"
tsISS.WriteLine "File=Response File"
tsISS.WriteLine "[File Transfer]"
tsISS.WriteLine "OverwrittenReadOnly=NoToAll"
tsISS.WriteLine "[" & CLSID & "-DlgOrder]"
tsISS.WriteLine "Dlg0=" & CLSID & "-SprintfBox-0"
tsISS.WriteLine "Count=2"
tsISS.WriteLine "Dlg1=" & CLSID & "-File Transfer"
tsISS.WriteLine "[" & CLSID & "-SprintfBox-0]"
tsISS.WriteLine "Result=1"
tsISS.WriteLine "[Application]"
tsISS.WriteLine "Name=Java 2 Runtime Environment, SE v1.4.0_01"
tsISS.WriteLine "Version=1.4.0_01"
tsISS.WriteLine "Company=JavaSoft"
tsISS.WriteLine "Lang=0009"
tsISS.WriteLine "[" & CLSID & "-File Transfer]"
tsISS.WriteLine "SharedFile=YesToAll"
tsISS.Close
strSetupexe = Left(strUninstallString, search4 + 9)
strUninstCMD = strSetupexe & strUnString & Chr(34) & strTempISS & "\" & CLSID & ".iss" & Chr(34)
End If
ts.WriteLine Now() & " - " & strDisplayName & " - Version: " & strDisplayVersion
ts.WriteLine Now() & " - Uninstall String sent: " & strUninstCMD
ret = wshShell.Run(strUninstCMD , 0, True)
End If
Loop
tsIn.Close
If Not blFound Then
ts.WriteLine Now() & " - No Old Java Runtime versions found installed."
qVal = 99
End If
ts.Close
fso.DeleteFolder(strTempISS)
fso.DeleteFile(strTempDir & "\uninstall.tmp")
WScript.Quit(qVal)
Sub PreFlight()
'# Creates temp files containing extracts from registry 'Uninstall' keys.
Dim wshShell, fso, sTemp
sTemp = wshShell.ExpandEnvironmentStrings("%temp%")
wshShell.Run "REGEDIT /E %temp%\registry.tmp HKEY_LOCAL_MACHINE\SOFTWARE\microsoft\windows\currentversion\uninstall", 0, True
wshShell.Run "cmd /c type %temp%\registry.tmp | find /i ""{"" | find /i ""}]"" > %temp%\uninstall.tmp ", 0, True
wshShell.Run "cmd /c type %temp%\registry.tmp | find /i ""JRE 1"" >> %temp%\uninstall.tmp ", 0, True
If Not fso.FileExists(sTemp & "\uninstall.tmp") Then
ts.WriteLine Now() & " - No input - %temp%\uninstall.tmp Reg extract not created."
ts.Close
WScript.Quit(1)
End If
End Sub
Sub KillProc()
'# kills jusched.exe and jqs.exe if they are running. These processes will cause the installer to fail.
Dim wshShell
wshShell.Run "Taskkill /F /IM jusched.exe /T", 0, True
wshShell.Run "net stop JavaQuickStarterService", 0, True
wshShell.Run "Taskkill /F /IM java.exe /T", 0, True
End Sub
Function KillJava()
Code:
Function KillJava()
'strComputer = "."
Set objWMIService = GetObject("winmgmts:{impersonationLevel=impersonate, (Debug)}\\.\root\cimv2")
'Kill java.exe process (unless running under SYSTEM account)
Set colProcessList = objWMIService.ExecQuery("SELECT * FROM Win32_Process WHERE Name = 'java.exe' OR Name = 'jusched.exe' OR Name = 'javaw.exe' OR Name = 'iexplore.exe'", "WQL", 48)
For Each objProcess in colProcessList
objProcess.Terminate()
Next
'Kill javaw.exe process (unless running under SYSTEM account)
'Set colProcessList = objWMIService.ExecQuery("SELECT * FROM Win32_Process WHERE Name = 'javaw.exe'")
'For Each objProcess in colProcessList
'objProcess.Terminate()
'Next
'Kill iexplore.exe process (unless running under SYSTEM account)
'Set colProcessList = objWMIService.ExecQuery("SELECT * FROM Win32_Process WHERE Name = 'iexplore.exe'")
'Next
End Function
Help?
