Sabotage23
- Aug 31, 2006
Hi all
i put together a VBS inventory script that can be run as a login script and output the information to a text file.
But i would like to upload the information to a SQL Table that i have created, im new to VBS and SQL and im learning along the way.
So far what i have will update the table but i get into some problems for example
'Get Hardware Information
Next
report = report & vbCrLf & "******************************************" & vbCrLf
report = report & "Hardware Information" & vbCrLf & "******************************************" & vbCrLf & vbCrLf
Set colSettings = objWMIService.ExecQuery _
("Select * from Win32_ComputerSystem")
for Each objComputer in colSettings
sHWInformation = "Insert INTO Hardware (System_Name, Manufacturer, Model) VALUES ('" & objComputer.Name & "','" & objComputer.Manufacturer & "','" & objComputer.Model & "')"
report = report & "System Name: " & objComputer.Name & vbCrLf
report = report & "System Manufacturer: " & objComputer.Manufacturer & vbCrlF
report = report & "System Model: " & objComputer.Model & vbCrLf
next
execute query
mConnection.Execute (sHWInformation)
but when i try to do this in the same table
'Get BIOS Information
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colBIOS = objWMIService.ExecQuery _
("Select * from Win32_BIOS",,48)
For each objBIOS in colBIOS
sBIOSinformation = "Insert INTO Hardware (BIOS_Version, Manufacturer) VALUES ('" & objBIOS.SMBIOSBIOSVersion & "','" & objBIOS.Manufacturer & "')"
report = report & "BIOS Version: " & objBIOS.SMBIOSBIOSVersion & vbCrLf
report = report & "Mother Board: " & objBIOS.Manufacturer & vbCrlF
Next
Execute query
mConnection.Execute (sBIOSinformation)
i get errors it is like if i cannot do 2 inserts in one table for different values. Is this even possible? will a UPDATE table work instead ???
Thanks for your help
Next
next
execute query
Next
Execute query
