VB6 RtfTextBox / excel Question
dave_p
I have an access database with a few fields that are rtf formatted text, i need to strip out the formatting and then load the tables into an oracle database. i exported the table to a .csv, and then wrote a few modules in vba to remove crlf's and such. i then wrote this procedure to strip out the rtf formatting:
Code:
Sub convert()
Dim pobjCell As Range
Dim plCharCounter As Long
Dim richtextbox1 As New RichTextBox
Dim psCellText As String
For Each pobjCell In Selection
psCellText = pobjCell.Text
richtextbox1.TextRTF = psCellText
pobjCell.Value = richtextbox1.Text
Next
End Sub
i keep getting an error runtime error 387, set not permitted
when i hover over the error, the tooltip from the code states:
get not supported (write-only property)
from all i have read, this was one of the more suggested methods of doing this. what am i missing?
Code:
Sub convert()
ActiveSheet.rtb.TextRTF = psCellText
pobjCell.Value = ActiveSheet.rtb.Text
Next
End Sub
what i did in this case to make it work was to just drag a richtextbox out onto the .csv file and then reference it in the macro.
if i wanted to do it in code, i would have to create a user form and then the rtbox and reference it from the form. for some reason it wouldnt just let me create the box in the macro.
