VB6 Bitmap
MjrStryker
I am trying to use avicap32.dll to capture a single bitmap from a webcam and manipulate the individual RGB values of the bitmap, but I'm not sure how to do the manipulation part in VB6. What I do have so far is a method that gets avicap32.dll to send the captured frame to the clipboard.
Code:
Call SendMessage(hCap, WM_CAP_EDIT_COPY, 0&, 0&)
Now when I try to access the bitmap that the dll placed on the clipboard, I'm unsure what object to use to store the data. Do I need to declare my own structure to pass the bytes into? is there some preconstructed Object for dealing with Bitmaps? How do I get the data from the clipboard into a form in which I can access the individual pixel RGB values?
I appreciate any help I can get on this matter.
