vB not forwarding login for domain hardforums.com
K
Kyo
Guest
When you attempt to login from hardforums.com (notice the "s"), it will not remember your login. Logging in from Hardforum.com works just fine. This usually happens in vB when the primary domain in cPanel is different than the parked domain.
1. That would be a issue as we don't use cpanel (<-- junk)
2. Its not parked, its forwarded.
3. Should be fixed now, its white listed correctly, try now.
Thanks for this note. Just now I was at www.hardforumS.com and was unable to login. It kept showing the login success screen then formwarding me to the home page without logging me in. I switched to www.hardforum.com and am able to login and post this
Ok, try now, had to make another change.
clear cookies for both domains, hardforum.com & hardforums.com, restart browser & login.
