three_sixteen
- Feb 15, 2002
Hey everyone.
I've been playing around a lot with the webbrowser object and the mshtml object library.
I'm having trouble though using webbrowser.readystate. When I click a form object (button) to submit a form the readystate of the browser isn't getting changed to loading. So when I try to do something on the next page that loads I start to run into problems if it hasn't completely loaded.
How can I monitor the webbrowser object while my program is running to tell if it's really busy or not?
Here's some sample code:
Code:
Public Function accept() As Boolean
timerWait.Enabled = True
If browserMain.ReadyState = WebBrowserReadyState.Loading Then
accept()
ElseIf browserMain.ReadyState = WebBrowserReadyState.Complete Then
browserMain.Update()
page = browserMain.Document.DomDocument
buttonElements = page.getElementsByTagName("input")
For Each obj As mshtml.IHTMLElement In buttonElements
If obj.getAttribute("value") = "ACCEPT " Then
obj.click()
timerWait.Interval = 500
End If
Next
Else
Return False
End If
End Function
Public Function closeTkt() As Boolean
closeTkt()
If obj.getAttribute("value") = "CLOSE " Then
obj.click()
End If
Next
Else
Return False
End If
End Function
